autoinstall
Profile Config Commands
Automatically installs firmware image and startup configuration parameters on to the selected device.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
autoinstall [configuration|firmware|start-interval <WORD>]
Parameters
| configuration |
Autoinstalls
startup configuration. Setup parameters are automatically configured on
devices using this profile. This option is disabled by default. |
| firmware |
Autoinstalls
firmware image. Firmware images are automatically installed on devices using
| start-interval
<WORD> |
Configures the
interval between system boot and start of autoinstall process (this is the
time, from system boot, after which autoinstall should start) |
nx9500-6C8809(config-profile-default-rfs4000)#autoinstall configuration
nx9500-6C8809(config-profile-default-rfs4000)#autoinstall firmware
nx9500-6C8809(config-profile-default-rfs4000)#show context
profile rfs4000 default-rfs4000
bridge vlan 1
bridging-mode isolated-tunnel
ip igmp snooping
ip igmp snooping querier
arp timeout 2000
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
crypto ikev2 policy ikev2-default
crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
crypto ikev1 remote-vpn
crypto ikev2 remote-vpn
--More--
Related Commands
| no |
Disables the auto install settings |
