Configures the SSID (and its character length) used as a match criteria
ssid-match [ssid|ssid-len]
ssid-match [ssid <SSID>|ssid-len <0-32>]
                         ssid <SSID>  |
                         Specifies the SSID match string
 Note: Specify the correct SSID to ensure proper filtering.
                         ssid-len <0-32>  |
                         Specifies the length of the SSID
nx9500-6C8809(config-test-signature-test)#ssid-match ssid PrinterLan
         nx9500-6C8809(config-test-signature-test)#show context signature test bssid 11-22-33-44-55-66 src-mac 00-1E-E5-EA-1D-60 dst-mac 55-66-77-88-99-00 frame-type beacon ssid-match ssid PrinterLan filter-ageout 8 payload 1 pattern test offset 1 nx9500-6C8809(config-test-signature-test)#
| no (wips-signature-config-mode-command) |
                         Removes the configured SSID  |
