A typical, large enterprise network, consists of multiple sites (RF Domains) having similar configuration parameters with few elements that vary, such as networks or network ranges, hosts having different IP addresses, and VLAN IDs or URLs. These elements can be defined as aliases (object oriented wireless firewalls) and used across sites by applying overrides to the object definition. Using aliases results in a configuration that is easier to understand and maintain.
Multiple instances of an alias (same type and same name) can be defined at any of the following levels: global, RF Domain, profile, or device. An alias defined globally functions as a top-level-object (TLO). Global aliases are not mandatory, and can be defined at the domain-level, or profile, or device-level only. An alias defined on a device is applicable to that device only. An alias defined on a profile applies to every device using the profile. Similarly, aliases defined at the RF Domain level apply to all devices within that domain.
Aliases defined at any given level can be overridden at any of the next lower levels. For example, a global alias can be redefined on a selected set of RF Domains, profiles, or devices. Overrides applied at the device level take precedence.
The different aliases types supported are:
A network-group alias can contain a maximum of eight (8) host entries, eight (8) network entries, and eight (8) IP address-range entries. A maximum of 32 network-group alias entries can be created.
A network-group alias can be used in IP firewall rules to substitute hosts, subnets, and IP address ranges.
Use a network-service alias to associate more than one IP address to a network interface, providing multiple connections to a network from a single IP node.
When used with ACLs, network, network-group, and network-service aliases act as enhanced firewalls.alias [address-range|encrypted-string|hashed-string|host|network|network-group| network-service|number|string|vlan]
alias address-range <ADDRESS-RANGE-ALIAS-NAME> <STARTING-IP> to <ENDING-IP>
alias encrypted-string <ENCRYPTED-STRING-ALIAS-NAME> [0|2] <LINE>
alias hashed-string <HASHED-STRING-ALIAS-NAME> <LINE>
alias host <HOST-ALIAS-NAME> <HOST-IP>
alias network <NETWORK-ALIAS-NAME> <NETWORK-ADDRESS/MASK>]
alias network-group <NETWORK-GROUP-ALIAS-NAME> [address-range|host|network]
alias network-group <NETWORK-GROUP-ALIAS-NAME> [address-range <STARTING-IP> to <ENDING-IP>
{<STARTING-IP> to <ENDING-IP>}|host <HOST-IP> {<HOST-IP>}|network <NETWORK-ADDRESS/MASK>
{<NETWORK-ADDRESS/MASK>}]
alias network-service <NETWORK-SERVICE-ALIAS-NAME> proto [<0-254>|<WORD>|eigrp|gre|igmp|
igp|ospf|vrrp] {(<1-65535>|<WORD>|bgp|dns|ftp|ftp-data|gopher|https|ldap|nntp|ntp|pop3|proto|sip|
smtp|sourceport|ssh|telnet|tftp|www)}
alias number <NUMBER-ALIAS-NAME> <0-4294967295>
alias string <STRING-ALIAS-NAME> <LINE>
alias vlan <VLAN-ALIAS-NAME> <1-4094>
| address-range <ADRESS-RANGE-ALIAS-NAME> | Creates an address range alias, defining a range of
IP addresses
Note: Alias
name should begin with ‘$‘.
| <STARTING-IP> to <ENDING-IP> | Associates a range of IP addresses with this address
range alias
| encrypted-string <ENCRYPTED-STRING-ALIAS-NAME> | Creates an alias for an encrypted string. Use this
alias for string configuration values that are encrypted
when "password-encryption" is enabled. For example, in
the management-policy, use it to define the SNMP
community string. For more information, see snmp-server (management policy config mode).
Note: Alias
| [0|2] <LINE> | Configures the value associated with the alias name
specified in the previous step
| hashed-string <HASHED-STRING-ALIAS-NAME> | Creates an alias for a hashed string. Use this alias
for configuration values that are hashed strings, such
as passwords. For example, in the management-policy, use
it to define the privilege mode password. For more
information, see privilege-mode-password.
Note: Alias
| <LINE> | Configures the hashed-string value associated with
this
alias.nx9500-6C8809(config)#show running-config ! alias encrypted-string $WRITE 2 sBqVCDAoxs3oByF5PCSuFAAAAAd7HT2+EiT/l/BXm9c4SBDv ! alias hashed-string $PriMode 1 faffdde27cb49ad634ea20df4f7c8ef2685894d10ffcb1b2efba054112ecfc75 0 --More-- nx9500-6C8809 In
the above |
| host <HOST-ALIAS-NAME> | Creates a host alias, defining a single network host
Note: Alias
| <HOST-IP> | Associates the network host‘s IP address with this
host alias. For example, ‘alias host $HOST 1.1.1.100‘.
In this example, the host alias name is: $HOST and the
host IP address it is mapped to is: 1.1.1.100.
| network <NETWORK-ALIAS-NAME> | Creates a network alias, defining a single network
address
Note: Alias
| <NETWORK-ADDRESS/MASK> | Associates a single network with this network alias.
For example, 'alias
network $NET 1.1.1.0/24‘. In this example, the
network alias name is: $NET and the network it is mapped to is: 1.1.1.0/24.
| network <NETWORK-GROUP-ALIAS-NAME> | Creates a network-group alias
Note: Alias
The network-group aliases are used in ACLs, to define the network-specific components. ACLs using aliases can be used across sites by re-defining the network-group alias elements at the device or profile level. After specifying the name, specify the following: a range of IP addresses, host addresses, or a range of network addresses. |
| address-range <STARTING-IP> to <ENDING-IP> {<STARTING-IP> to <ENDING-IP>} | Associates a range of IP addresses with this
network-group alias
| host <HOST-IP> {<HOST-IP>} | Associates a single or multiple hosts with this
network-group alias
| network <NETWORK-ADDRESS/MASK> {<NETWORK-ADDRESS/MASK>} | Associates a single or multiple networks with this
network-group alias
smtp|sourceport [<1-65535>|<WORD>]|ssh|telnet|tftp|www)}
| alias network-service <NETWORK-SERVICE-ALIAS-NAME> | Configures an alias that specifies available network
services and the corresponding source and destination
software ports
Note: Alias
Network-service aliases are used in ACLs, to define the service-specific components. ACLs using aliases can be used across sites by re-defining the network-service alias elements at the device or profile level. |
| proto [<0-254>| <WORD>|eigrp|gre| igmp|igp|ospf|vrrp] | Use one of the following options to associate an
Internet protocol with this network-service alias:
| {(<1-65535>| <WORD>| bgp|dns|ftp|ftp-data| gopher|https|ldap| nntp|ntp|pop3|proto| sip|smtp|sourceport [<1-65535>| <WORD>]|ssh|telnet| tftp|www)} | After specifying the protocol, you may configure a
destination port for this service. These keywords are
recursive and you can configure multiple protocols and
associate multiple destination and source ports.
| alias number <NUMBER-ALIAS-NAME> <0-4294967295> | Creates a number alias identified by the
<NUMBER-ALIAS-NAME> keyword. Number aliases map a
name to a numeric value. For example, ‘alias
number $NUMBER 100‘. In this example:
| alias string <STRING-ALIAS-NAME> | Creates a string alias identified by the
<STRING-ALIAS-NAME> keyword
String aliases map a name to an arbitrary string
value. For example, ‘alias string $DOMAIN
test.example_company.com‘. In this example,
The value referenced by alias $DOMAIN, wherever used, is test.example_company.com. You can also use a string alias to configure the Bonjour Service instance name. Once configured, use the string alias in the Bonjour Gateway Discovery Policy context to specify the Bonjour service instance name to be used as the match criteria. For more information, see bonjour-gw-discovery-policy. |
| alias vlan <VLAN-ALIAS-NAME> | Creates a VLAN alias identified by the
<VLAN-ALIAS-NAME> keyword
Note: Alias
| <1-4094> | Maps the VLAN alias to a VLAN ID
nx9500-229D58(config)#alias address-range $TestAddRanAlias 192.168.13.10 to 192.168.13.13
nx9500-229D58(config)#alias network $TestNetworkAlias 192.168.13.0/24
nx9500-229D58(config)#alias host $TestHostAlias 192.168.13.100
nx9500-229D58(config)#alias vlan $TestVLANAlias 1
nx9500-229D58(config)#alias address-range $AddRangeAlias 192.168.13.2 to 192.168.13.10
nx9500-229D58(config)#alias network-service $NetServAlias proto igmp
nx9500-229D58(config)#show running-config | include alias alias network-group $NetGrAlias address-range 192.168.13.7 to 192.168.13.9 192.168.13.20 to 192.168.13.25 alias network $NetworkAlias 192.168.13.0/24 alias host $HostAlias 192.168.13.10 alias address-range $AddRangeAlias 192.168.13.2 to 192.168.13.10 alias network-service $NetServAlias proto igmp alias vlan $VlanAlias 1 nx9500-229D58(config)#
nx9500-6C8809(config)#alias number $NUMBER 100
nx9500-6C8809(config)#show context include-factory | include alias alias string $DOMAIN test.examplecompany.com alias string $DOMAIN2 test.example_company.com alias number $NUMBER 100 alias string $SN B4C7996C8809 nx9500-6C8809(config)#
The following examples show encrypted-string alias configuration:
nx9500-6C8809(config)#alias encrypted-string $WRITE 0 private
nx9500-6C8809(config)#alias encrypted-string $READ 0 public
nx9500-6C8809(config)#show context | include alias alias vlan $BLR-01 1 alias string $IN-Blr-EcoSpace-Floor-4 IBEF4 alias encrypted-string $READ 0 public alias encrypted-string $WRITE 0 private nx9500-6C8809(config)#
The following example shows the encrypted-string aliases, configured in the previous example, used in the management-policy:
nx9500-6C8809(config-management-policy-default)#snmp-server community 0 $WRITE rw
nx9500-6C8809(config-management-policy-default)#snmp-server community 0 $READ ro
nx9500-6C8809(config-management-policy-default)#show context management-policy default no telnet no http server https server rest-server ssh user admin password 1 ad4d8797f007444ccdda3788b9ee0e8b46f3facb4308e045239eb7771e127ed5 role superuser access all snmp-server community 0 $WRITE rw snmp-server community 0 $READ ro snmp-server user snmptrap v3 encrypted des auth md5 2 yqr96yyVzmD4ZbU2I7Eh/QAAAAjWNKa4KXF95pruUCSnhOiT snmp-server user snmpmanager v3 encrypted des auth md5 2 NOf8+2+AY2r4ZbU2I7Eh/QAAAAgc0l8ahJYo3AjHo9wXzYGo t5 snmp-server community public ro 192.168.0.1 t5 snmp-server community private rw 192.168.0.1 nx9500-6C8809(config-management-policy-default)#
The following example shows hashed-string alias configuration:
nx9500-6C8809(config)#alias hashed-string $PriMode Test12345
nx9500-6C8809(config)#show context | include alias alias vlan $BLR-01 1 alias string $IN-Blr-EcoSpace-Floor-4 IBEF4 alias encrypted-string $READ 0 public alias encrypted-string $WRITE 0 private alias hashed-string $PriMode 1 faffdde27cb49ad634ea20df4f7c8ef2685894d10ffcb1b2efba054112ecfc75 nx9500-6C8809(config)#
The following example shows the hashed-string alias, configured in the previous example, used in the management-policy:
nx9500-6C8809(config-management-policy-default)#show context management-policy default https server rest-server ssh user admin password 1 ad4d8797f007444ccdda3788b9ee0e8b46f3facb4308e045239eb7771e127ed5 role superuser access all snmp-server community 0 $WRITE rw snmp-server community 0 $READ ro snmp-server user snmptrap v3 encrypted des auth md5 2 yqr96yyVzmD4ZbU2I7Eh/QAAAAjWNKa4KXF95pruUCSnhOiT snmp-server user snmpmanager v3 encrypted des auth md5 2 NOf8+2+AY2r4ZbU2I7Eh/QAAAAgc0l8ahJYo3AjHo9wXzYGo t5 snmp-server community public ro 192.168.0.1 t5 snmp-server community private rw 192.168.0.1 privilege-mode-password $PriMode nx9500-6C8809(config-management-policy-default)#
| no | Removes an existing network, VLAN, service, or string alias |
