Configures 802.1X authenticator settings
Dot1x (or 802.1x) is an IEEE standard for network authentication. It enables media-level (layer 2) access control, providing the capability to permit or deny connectivity based on user or device identity. Dot1x allows port-based access using authentication. An dot1x enabled port can be dynamically enabled or disabled depending on user identity or device connection.
Devices supporting dot1x allow the automatic provision and connection to the wireless network without launching a Web browser at login. When within range of a dot1x network, a device automatically connects and authenticates without needing to manually login.
Before authentication, the endpoint is unknown, and traffic is blocked. Upon authentication, the endpoint is known and traffic is allowed. The controller or service platform uses source MAC filtering to ensure only the authenticated endpoint is allowed to send traffic.
dot1x authenticator [guest-vlan|host-mode|max-reauth-req|port-control|reauthenticate|timeout]
dot1x authenticator [guest-vlan <1-4094>|host-mode [multi-host|single-host]|max-reauth-req <1-10>| port-control [auto|force-authorized|force-unauthorized]|reauthenticate|timeout [quiet-period|reauth-period] <1-65535>]
The dot1x (802.1x) supplicant settings are documented in the next section.dot1x authenticator [guest-vlan <1-4094>|host-mode [multi-host|single-host]| max-reauth-req <1-10>|port-control [auto|force-authorized|force-unauthorized]| reauthenticate|timeout [quiet-period|reauth-period]]
dot1x authenticator | Configures 802.1x authenticator settings |
guest-vlan <1-4094> | Configures the guest VLAN for this interface. This is the VLAN, traffic is bridged on if this port is unauthorized and the guest VLAN is globally enabled. Select the VLAN index from 1 - 4094. |
host-mode [multi-host| single-host] | Configures the
host mode for this interface
max-reauth-req <1-10> | Configures
maximum number of re-authorization retries for the supplicant. This is the
maximum number of re-authentication attempts made before this port is moved
to unauthorized.
port-control [auto| force-authorized| force-unauthorized] | Configures port
control state
reauthenticate | Enables re-authentication for this port. When enabled, clients are forced to re-authenticate on this port. The setting is disabled by default. Therefore, clients are not required to re-authenticate for connection over this port until this setting is enabled. |
timeout [quiet-period|reauth-period] <1-65535> | Configures
timeout settings for this interface
The following option is common to ‘quiet-period‘ and ‘reauth-period‘ keywords:
nx9500-6C8809(config-profile-testNX5500-if-ge1)#dot1x authenticator guest-vlan 2 nx9500-6C8809(config-profile-testNX5500-if-ge1)#dot1x authenticator host-mode multi-host nx9500-6C8809(config-profile-testNX5500-if-ge1))#dot1x authenticator max-reauth-req 6 nx9500-6C8809(config-profile-testNX5500-if-ge1)#dot1x authenticator reauthenticate nx9500-6C8809(config-profile-testNX5500-if-ge1)#show context interface ge1 dot1x authenticator host-mode multi-host dot1x authenticator guest-vlan 2 dot1x authenticator reauthenticate dot1x authenticator max-reauth-count 6 ip dhcp trust qos trust dscp qos trust 802.1p nx9500-6C8809(config-profile-testNX5500-if-ge1)#
The following examples show the configurations made on an NX5500 to enable it as a dot1X authenticator:
NX5500-229D58(config-aaa-policy-aaa-wireddot1x)#show context aaa-policy aaa-wireddot1x authentication server 1 onboard controller NX5500-229D58(config-aaa-policy-aaa-wireddot1x)#
This AAA policy is used in the authenticator‘s self configuration mode as shown in the last step.
nx5500-229D58(config-radius-user-pool-wired-dot1x-users)#show con radius-user-pool-policy wired-dot1x-users user bob password 0 bob1234 nx5500-229D58(config-radius-user-pool-wired-dot1x-users)#
The user name and password configured here should match that of the supplicant. For more information, see the examples provided in the dot1x (supplicant) section.
nx5500-229D58(config-radius-server-policy-for-wired-dot1x)#show con radius-server-policy for-wired-dot1x use radius-user-pool-policy wired-dot1x-users nx5500-229D58(config-radius-server-policy-for-wired-dot1x)#
nx5500-229D58(config-device-00-15-29-22-9D-58)#use radius-server-policy for-wired-dot1x
nx5500-229D58(config-device-00-15-29-22-9D-58-if-ge2)#dot1x authenticator host-mode single-host
nx5500-229D58(config-device-00-15-29-22-9D-58-if-ge2)#dot1x authenticator port-control auto
nx5500-229D58(config-device-00-15-29-22-9D-58)#dot1x system-auth-control
nx5500-229D58(config-device-00-15-29-22-9D-58)#dot1x use aaa-policy aaa-wireddot1x
Following example displays the above configured parameters:
nx5500-229D58(config-device-00-15-29-22-9D-58)#show context use profile default-nx5500 use rf-domain default hostname nx5500-229D58 use radius-server-policy for-wired-dot1x interface me1 ip address 192.168.0.1/24 interface ge2 dot1x authenticator host-mode single-host dot1x authenticator port-control auto interface vlan1 ip address dhcp ip dhcp client request options all logging on logging console debugging dot1x system-auth-control dot1x use aaa-policy aaa-wireddot1x --More-- nx5500-229D58(config-device-00-15-29-22-9D-58)
no | Disables or reverts interface settings to their default |
