AP510e Specifications
            AP510e is a next generation,
                enterprise-class 802.11ax access point. The AP features a dual-band radio, a band
                locked radio, and comes with eight (8) WiFi external antennas and one BLE
                antenna.
                - Radios: 2 radios (1 dual band,
                    2.4GHz and 5GHz, and 1 band locked 5GHz); 1 IoT radio (2.4 GHz).
                - Console Port: RJ45.
                - Two Ethernet Ports:
                        - GE1 -
                            10/100/1000/2500/5000 Mbps auto-negotiation Ethernet port, RJ45, with
                            PoE In
                        - GE2 - 10/100/1000 Mbps
                            auto-negotiation Ethernet port, RJ45, with PoE In
                - LEDs: 6 – All LEDs will be on
                    during reset
                - One Reset button
                - Power: PoE 802.3at; 12VDC
                    external power in connector.
                - Antennas:
                        - Eight WiFi external
                            antennas
                        - One BLE internal
                            antenna
