Defines the session flow timeout interval for different packet types
flow [dhcp|timeout]
flow dhcp stateful
flow timeout [icmp|other|tcp|udp]
flow timeout [icmp|other] <1-32400>
flow timeout udp <15-32400>
flow timeout tcp [close-wait|reset|setup|stateless-fin-or-reset| stateless-general] <1-32400>
flow timeout tcp established <15-32400>
flow dhcp stateful
dhcp |
Configures DHCP packet flow |
stateful |
Performs a stateful check on DHCP packets. This feature is enabled by default. |
timeout |
Configures a packet timeout |
icmp |
Configures the timeout for ICMP packets. The default is 30 seconds. |
other |
Configures the timeout for packets other than ICPM, TCP, or UDP. The default is 30 seconds. |
<1-32400> |
Specify the timeout from 1 - 32400 seconds. |
timeout |
udp |
Configures the timeout for UDP packets. The default is 30 seconds. |
<15-32400> |
Specify the timeout from 15 - 32400 seconds. |
flow timeout tcp [close-wait|reset|setup|stateless-fin-or-reset|stateless-general] <1-32400>
timeout |
tcp |
Configures the timeout for TCP packets |
close-wait |
Configures the closed TCP flow timeout. The default is 10 seconds. |
reset |
Configures the reset TCP flow timeout. The default is 10 seconds. |
setup |
Configures the opening TCP flow timeout. The default is 10 seconds. |
stateless-fin-or-reset |
Configures stateless TCP flow timeout created with the FIN or RESET packets. The default is 10 seconds. |
stateless-general |
Configures the stateless TCP flow timeout. The default is 90 seconds (1 m 30s). |
<1-32400> |
timeout |
Configures the packet timeout |
tcp |
established |
Configures the established TCP flow timeout. The default is 5400 seconds. |
<15-32400> |
nx9500-6C8809(config-fw-policy-testFW)#flow timeout udp 10000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout icmp 16000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout other 16000
nx9500-6C8809(config-fw-policy-testFW)#flow timeout tcp established 1500
nx9500-6C8809(config-fw-policy-testFW)#show context firewall-policy testFW no ip dos tcp-sequence-past-window flow timeout icmp 16000 flow timeout udp 10000 flow timeout tcp established 1500 flow timeout other 16000 dhcp-offer-convert alg facetime dns-snoop entry-timeout 1200 nx9500-6C8809(config-fw-policy-testFW)#
no | Removes session timeout intervals configured for different packet types |
