If enforcing authenticated access to a database, use this command to generate the keyfile. Every keyfile has a set of associated users having a username and password. Access to the database is allowed only if the user credentials entered during database login are valid. For more information on enabling database authentication, see Enabling Database Authentication.
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.database [drop|keyfile|repair]
database drop [all|captive-portal]
database repair {on <DEVICE-NAME>}
      database keyfile [export|generate|import|zerzoise]
database keyfile generate
database keyfile [export|import] <URL>
database keyfile zerzoise
| database drop [all|captive-portal|] | Drops (deletes) all or a specified database. Execute the command on the device
                hosting the database.
      | database repair on <DEVICE-NAME> | Enables automatic repairing of all databases. Repairing (vacuuming a database
                refers to the process of finding and reclaiming space left over from previous DELETE
                statements. Execute the command on the database host.
 Note: If no device is specified,
                  the system repairs all databases.
| database keyfile generate | Enables database keyfile management. This command is part
                of a set of configurations required to enforce database
                authentication. Use this command to generate database keyfiles.
                After generating the keyfile, create the username and password
                combination required to access the database. For information on
                creating database users, see service. For information on enabling database
| database keyfile [export|import] <URL> | Enables database keyfile management. This command is part of a set of
                configurations required to enforce database authentication. Use this command to
                exchange keyfiles between replica set members.
 The following parameter is common to both of the above keywords:
| database keyfile zerzoise | Enables database keyfile management. Use this command to delete keyfiles
vx9000-1A1809#database keyfile generate Database keyfile successfully generated vx9000-1A1809#
vx9000-1A1809#database keyfile export ftp://1.1.1.111/db-key Database keyfile successfully exported vx9000-1A1809#
vx9000-D031F2#database keyfile import ftp://1.1.1.111/db-key Database keyfile successfully imported vx9000-D031F2#
Follow the steps below to enable database authentication and set up the onboard database. Note that this example uses replica set database deployment.
Primary-DB-HOST>database keyfile generate Database keyfile successfully generated Primary-DB-HOST>
Primary-DB-HOST>database keyfile export ftp://1.1.1.111/db-key Database keyfile successfully exported Primary-DB-HOST>
Primary-DB-HOST#service database authentication create-user username techpubs password techPubs@123 Database user [techpubs] created. Primary-DB-HOST#
Primary-DB-HOST#show database users
         DATABASE USER
 techpubs
Primary-DB-HOST#
Secondary-DB-HOST#database keyfile import ftp://1.1.1.111/db-key
Primary-DB-HOST(config-database-policy-techpubs)#authentication
Primary-DB-HOST(config-database-policy-techpubs)#authentication username techpubs password S540QFZz9LzSOdX1ZJEqDgAAAAy3b7GtyO4Z/Ih2ruxnOYnr
Primary-DB-HOST(config-database-policy-techpubs)#show context database-policy techpubs authentication authentication username techpubs password 2 S540QFZz9LzSOdX1ZJEqDgAAAAy3b7GtyO4Z/Ih2ruxnOYnr replica-set member nx7500-A02B91 arbiter replica-set member vx9000-1A1809 priority 1 replica-set member vx9000-D031F2 priority 20 Primary-DB-HOST(config-database-policy-techpubs)#
Primary-DB-HOST(config-device-B4-C7-99-6C-88-09)#use database-policy techpubs
This configuration is needed in deployments implementing captive-portal registration and database authentication with an onboard database.NOC-Controller(config-database-client-policy-techpubs)#authentication username techpubs password S540QFZz9LzSOdX1ZJEqDgAAAAy3b7GtyO4Z/Ih2ruxnOYnr
NOC-Controller(config-database-client-policy-techpubs)#show context database-client-policy techpubs authentication username techpubs password 2 S540QFZz9LzSOdX1ZJEqDgAAAAy3b7GtyO4Z/Ih2ruxnOYnr NOC-Controller(config-database-client-policy-techpubs)#
<DB-CLIENT>(config-device-B4-C7-99-6C-88-09)#use database-client-policy techpubs
| database-backup | Backs up all databases to a specified location and file on an FTP or SFTP server |
| database-restore | Restores a previously exported databases |
| database-policy global config | Documents database-policy configuration commands. Use this option to enable a WiNG device as the database. |
| database-client-policy global-config | Documents database-client-policy configuration commands. The database-client-policy is only needed in deployments implementing captive-portal registration and database authentication with an onboard database. Use this command to enable the controller or RF Domain manager to authenticate with the database. |
| service | Documents the database user account configuration details |
