channel-width
Selects the channel width for Smart RF configuration
Syntax
channel-width [2.4GHz|5GHz|6GHz]
channel-width 2.4GHz [20MHz|40MHz|auto]
channel-width 5GHz [20MHz|40MHz|80MHz|auto]
channel-width 6GHz [20MHz|40MHz|80MHz|160MHz|auto]
channel-width (2.4GHz|5GHz|6GHz) (20MHz|40MHz|80MHz|160MHz|auto)
Parameters
Assigns the channel width for the 2.4 GHz band
  • 20MHz – Assigns the 20 MHz channel width. This is the default setting.
  • 40MHz – Assigns the 40 MHz channel width
  • auto – Auto-selects the channel. Assigns the best possible channel in the 20 MHz or 40 MHz channel width.
channel-width 5GHz [20MHz|40MHz|auto]
channel-width 5GHz [20MHz|40MHz|auto] Assigns the channel width for the 5.0 GHz band
  • 40MHz – Assigns the 40 MHz channel width. This is the default setting.
  • 80MHz – Assigns the 80 MHz channel width
  • auto – Auto-selects the channel. Assigns the best possible channel in the 20 MHz or 40 MHz or 80 MHz channel width.
channel-width 6GHz [20MHz|40MHz|80MHz|160MHz|auto] Assigns the channel width for the 6.0 GHz band
  • 160MHz– Assigns the 160 MHz channel width
Usage Guidelines
The 20/40 MHz operation allows the access point to receive packets from clients using 20 MHz, and transmit using 40 MHz. This mode is supported for 802.11n users on both the 2.4 GHz and 5.0 GHz radios. If an 802.11n user selects two channels (a primary and secondary channel), the system is configured for dynamic 20/40 operation. When 20/40 is selected, clients can take advantage of wider channels. 802.11n clients experience improved throughput using 40 MHz while legacy clients (either 802.11a or 802.11b/g depending on the radio selected) can still be serviced without interruption using 20 MHz. Select auto to enable automatic assignment of channels to working radios to avoid channel overlap and avoid interference from external RF sources.
nx9500-6C8809(config-smart-rf-policy-test)#channel-width 2.4GHz auto
nx9500-6C8809(config-smart-rf-policy-test)#channel-width 5GHz auto
nx9500-6C8809(config-smart-rf-policy-test)#show context
smart-rf-policy test
 assignable-power 2.4GHz max 20
 assignable-power 2.4GHz min 8
 channel-list 2.4GHz 1,12
 area test channel-list 2.4GHz 1,2,3
 avoidance-time dfs 300
Related Commands
no (smart-rf-policy-config-mode-command) Resets channel width for the selected frequency to its default
