duplex
interface-config-port-channel-instance
Configures the duplex-mode (that is the data transmission mode) for this port channel interface
Syntax
duplex [auto|half|full]
Parameters
duplex [auto|half|full] Configures the mode of data transmission as auto, full, or half
  • auto – Select this option to enable the controller, service platform, or access point to dynamically duplex as port channel performance needs dictate. This is the default setting.
  • full – Select this option to simultaneously transmit data to and from the port channel.
  • half – Select this option to send data over the port channel, then immediately receive data from the same direction in which the data was transmitted.
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#duplex full
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
 interface port-channel1
  description "This port-channel is for enabling dynamic LACP."
  duplex full
Related Commands
no Reverts the duplex-mode to the default value (auto)
