The following table summarizes the client-identity configuration mode commands:
Command | Description |
dhcp | Configures the DHCP option match criteria for device fingerprinting |
dhcp-match-message-type | Configures the DHCP message type for device fingerprinting |
no (client-identity-config-mode) | Removes the DHCP option (used for client identification) configurations |
