11axTWT
The IEEE 802.11ax
standard defines power saving enhancements and improved resource scheduling features
including scheduled sleep and wake times. The Target Wake Time (TWT) option
allows devices, APs and stations, to negotiate when and how frequently they will wake up
to send or receive data. TWT increases device sleep time, thereby substantially
improving the client device's battery life. Use this command to enable 11ax TWT
support on the radio. TWT is disabled by default.
Supported in the
following platforms:
- Access Points — AP5010, AP310i/e,
AP410i/e,
AP460i/e, AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612,
AP7632, AP7662, AP8432, AP8533
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#11axTWT
ap510-133B38(config-device-94-9B-2C-13-3B-38-if-radio1)#show context
interface radio1
11axSupport
11axOFDMA both
11axTWT
11axBSScolor 20
