update-source (bgp-neighbor-config)
Allows BGP sessions to use any operational interface to establish the TCP connection with this neighbor
Syntax
update-source <IPv4>
Parameters
update-source <IPv4> Specify the BGP enabled neighbor‘s IPv4 address.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#update-source 192.168.13.1
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
  bgp neighbor 192.168.13.99
   remote-as 100
   advertisement-interval 100
   peer-group eBGPPeerGrp1
   port 21
   strict-capability-match
   timers connect 20
   timers 20 40
   allowas-in 10
   attribute-unchanged as-path
   capability orf prefix-list both
   default-originate
   description neighbor "This neighbor is an external AS neighbor"
   disable-connected-check
   dont-capability-negotiate
   ebgp-multihop 20
   enforce-multihop
   local-as 20 no-prepend
   maximum-prefix 400 50 warning-only
   next-hop-self
   override-capability
   passive
   password neighbor eBGPneighbor@300
   remove-private-as
   route-server-client
   send-community both
Related Commands
no (bgp-neighbor-config) Removes the source of routing updates
