handoff-threshold
Configures the handoff-threshold, which specifies client status for handoff-action. Once exceeded an action is invoked.
Syntax
handoff-threshold <-100--40>
Parameters
  • <-100--40> – Specify the RSSI value from -100 dBm - -40 dBm. The default is -80 dBm.
If the client‘s RSSI increases beyond the set handoff-threshold, it is removed from the queue for monitoring and action invocation.
nx9500-6C8809(config-roaming-assist-policy-test)#handoff-threshold -75
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 aggressiveness medium-high
 handoff-count 5
 detection-threshold -90
 action log
 disassoc-time 7
Related Commands
no Removes the configured handoff-threshold details
