no (client-identity-group-config-mode)
Removes the client identity associated with the client identity group
Syntax
no [client-identity|load]
no client-identity <CLIENT-IDENTITY-NAME> precedence <1-10000>
no load default-fingerprints
Parameters
Disassociates a specified client identity from this client identity group
  • <CLIENT-IDENTITY-NAME> – Specify the client identity name.
    • precedence <1-10000> – Specify the above specified client identity‘s precedence value from <1-10000>.
The client identity rule is applied based on its precedence value. Lower the value, higher is the precedence. Therefore, a client identity with precedence 5 gets precedence over a client identity having precedence 20.
no load default-fingerprints Disables automatic loading of built-in, system-provided client identity fingerprints
nx9500-6C8809((config-client-identity-group-test)#show context
client-identity-group test
 client-identity test precedence 1
<exsw5>(config-client-identity-group-test)#
nx9500-6C8809((config-client-identity-group-test)#no client-identity test
