l2-tunnel-forward-additional-packet-types
bridge
Enables forwarding of WNMP (Wireless Network Management Protocol) packets across L2 tunnels. Under normal circumstances, if L2 tunnel broadcast optimization is enabled. WNMP packets are not forwarded across the L2 tunnels. Use this option to enable the forwarding of only WNMP packets.
Syntax
l2-tunnel-forward-additional-packet-types wnmp
Parameters
None
nx9500-6C8809(config-profile testNX9000-bridge-vlan-1)#l2-tunnel-forward-additional-packet-types wnmp
nx9500-6C8809(config-profile testNX9000-bridge-vlan-1)#show context
 bridge vlan 1
  l2-tunnel-broadcast-optimization
  ip igmp snooping
  ip igmp snooping querier
  ipv6 mld snooping
  ipv6 mld snooping querier
Related Commands
no Disables WNMP packet forwarding across L2 tunnel
