interface-config-radio-instance
Configures the selected radio‘s transmit power. Use this command to manually set the transmit power of the selected radio, or select the smart mode by which the transmit power is determined.
power [<1-30>|smart]
power | Configures the selected radio‘s transmit power |
<1-30> | Configures the
transmit power from 1 - 30 dBm (actual power could be lower based on
regulatory restrictions) For APs with dual or three radios, use this option to manually configure each radio with a unique transmit power in respect to its intended client support function. |
smart | Enables Smart RF
to determine the optimum transmit power needed. Use this option to let Smart
RF determine the selected radio's transmit power. If you are using this
option for RF management, ensure that a Smart RF policy is configured and
applied to the AP's RF Domain context. You can also use the default Smart RF
policy. Note: By default,
APs use Smart RF to determine transmit power.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#power 12
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 power 12 data-rates b-only placement outdoor mesh client off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 non-unicast tx-rate bss 1 dynamic-all non-unicast tx-rate bss 2 highest-basic non-unicast tx-rate bss 3 highest-basic non-unicast tx-rate bss 4 highest-basic non-unicast tx-rate bss 5 highest-basic non-unicast tx-rate bss 6 highest-basic non-unicast tx-rate bss 7 highest-basic --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
no (radio-interface-config-command) | Resets a radio‘s transmit power |
