wireless-client [count-per-radio|cred-cache-ageout|hold-time|inactivity-timeout| max-firewall-sessions|reauthentication|roam-notification|tx-power|t5-inactivity-timeout| vlan-cache-out]
wireless-client [count-per-radio <0-256>|cred-cache-ageout <60-86400>|hold-time <1-86400>| inactivity-timeout <60-86400>|max-firewall-sessions <10-10000>|reauthentication <30-86400>| t5-inactivity-timeout <60-86400>|tx-power <0-20>|vlan-cache-ageout <60-86400>]
wireless-client roam-notification [after-association|after-data-ready|auto]
wireless-client [count-per-radio <0-256>|cred-cache-ageout <60-86400>| hold-time <1-86400>|inactivity-timeout <60-86400>|max-firewall-sessions <10-10000>| reauthentication <30-86400>|t5-inactivity-timeout <60-86400>|tx-power <0-20>| vlan-cache-ageout <60-86400>]
| wireless-client | Configures the transmit power indicated to wireless clients for transmission |
| count-per-radio <0-256> | Configures the maximum number of clients allowed
                        on this WLAN per radio
| cred-cache-ageout <60-86400> | Configures the timeout period for which client credentials are cached
                        across associations
| hold-time <1-86400> | Configures the time period for which wireless client state information
                        is cached post roaming
| inactivity-timeout <60-86400> | Configures an inactivity timeout period in seconds. If a frame is not
                        received from a wireless client for this period of time, the client is
                           disassociated.
| max-firewall-sessions <10-10000> | Configures the maximum firewall sessions allowed per client on a WLAN
| reauthentication <30-86400> | Configures periodic reauthentication of associated clients
| t5-inactivity-timeout <60-86400> | Configures and inactivity timeout, in seconds, for T5 devices. When
                        configured, the T5 device is disassociated if the time lapsed after the last
                        frame received from it exceeds the value specified here.
| tx-power <0-20> | Configures the transmit power indicated to clients
| vlan-cache-ageout <60-86400> | Configures the timeout period for which client VLAN information is
                        cached across associations.
| roam-notification | Configures when a roam notification is transmitted |
| after-association | Transmits a roam notification after a client has associated |
| after-data-ready | Transmits a roam notification after a client is data-ready (after completion of authentication, handshakes etc.) |
| auto | Transmits a roam notification upon client association (if the client is known to have authenticated to the network) |
nx9500-6C8809(config-wlan-test)#wireless-client cred-cache-ageout 65
         nx9500-6C8809(config-wlan-test)#wireless-client hold-time 200
         nx9500-6C8809(config-wlan-test)#wireless-client max-firewall-sessions 100
         nx9500-6C8809(config-wlan-test)#wireless-client reauthentication 35
         nx9500-6C8809(config-wlan-test)#wireless-client tx-power 12
         nx9500-6C8809(config-wlan-test)#show context wlan test ssid testWLAN1 vlan-pool-member 1 limit 1 vlan-pool-member 2 limit 1 vlan-pool-member 3 limit 1 vlan-pool-member 4 limit 1 vlan-pool-member 5 limit 1 vlan-pool-member 6 limit 1 vlan-pool-member 7 limit 1 vlan-pool-member 8 limit 1 vlan-pool-member 9 limit 1 vlan-pool-member 10 limit 1 bridging-mode local encryption-type none authentication-type none wireless-client hold-time 200 wireless-client cred-cache-ageout 65 wireless-client max-firewall-sessions 100 protected-mgmt-frames mandatory wireless-client reauthentication 35 wep64 key 1 hex 0 7465737431 wep128 key 1 hex 0 25f6e7ed9718918a87a75acc75 wep128 key 2 hex 0 2b3fb36924b22dffe98c86c315 wep128 key 3 hex 0 1ebf3394431700194762ebd5b2 wep128 key 4 hex 0 e3de75be311bd787aeac5e4e8b radius vlan-assignment time-based-access days weekdays start 10:00 end 16:30 wing-extensions wmm-load-information wireless-client tx-power 12 client-load-balancing probe-req-intvl 5ghz 5 --More-- nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Removes or reverts to default configured wireless client related parameters |
