no (iot-device-type-imagotag-policy)
Reverts this IoT Device-Type Imagotag policy settings to default values
Syntax
no [channel|enable|fcc-mode|output-power|payload-size|port|server|ssl|window-size]
Parameters
no <PARAMETERS>
no <PARAMETERS> Reverts this IoT Device-Type Imagotag policy settings to default value
The following example shows the Imagotag policy settings before the no commands are executed:
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no ?
iot-device-type-imagotag-policy test
  enable
  output-power Level-B
  window-size 12
  payload-size 25
  ssl
  fcc-mode
  channel 9
  server ip-address 10.234.160.225
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no payload-size
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no window-size
NOC-NX9500(config-iot-device-type-imagotag-policy-test)#no server
The following example shows the Imagotag policy settings after the ‘no‘ commands are executed:
nx9500-6C8809(config-iot-device-type-imagotag-policy-test)#show context
  enable
  ssl-enable
  fcc-enable
  channel 9
