fallback
Enables fallback to destination-based routing. This option is enabled by default. To disable fallback, use the no → fallback command.
The action taken for packets satisfying the match criteria is determined by the mark (action) clauses. If no action is defined, the default is to fallback to destination-based routing.
If no mark clause is configured and fallback to destination-based routing is disabled, then the packet is dropped.
Syntax
fallback
Parameters
None
nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#fallback
Related Commands
no (route-map-config-mode-command) Disables fallback to destination-based routing if no next hop is configured or are unreachable
