flash-uiNEW!
Enables the Flash user interface (UI) on a device. The following rules apply:
Syntax
flash-ui
no flash-ui
Parameters
None
The following example shows the current settings for the management policy named test-cw. In this example, flash-ui is not enabled, which is the default setting.
vx9000-3C6F18#
vx9000-3C6F18#config
Enter configuration commands, one per line.  End with CNTL/Z.
vx9000-3C6F18(config)#management-policy test-cw
vx9000-3C6F18(config-management-policy-test-cw)#show context
 no telnet
 no http server
 nova
 no flash-ui
 https server
 rest-server
 ssh
 ssh enable-weak-mac-algo 1
In the following example, flash-ui is first enabled, then it is disabled using the no command.
vx9000-3C6F18(config-management-policy-test-cw)#flash-ui
 no telnet
 no http server
 nova
 flash-ui
 https server
 rest-server
 ssh
vx9000-3C6F18(config-management-policy-test-cw)#no flash-ui
 no telnet
 no http server
 nova
 no flash-ui
 https server
 rest-server
 ssh
In the following example, flash-ui and https server are enabled. In this case, the Flash UI is reachable on port 10443.
 no telnet
 no http server
 nova
 flash-ui
 https server
 rest-server
 ssh
In the following example, flash-ui and http server are enabled. In this case, the Flash UI is reachable on port 10080.
vx9000-3C6F18(config-management-policy-test-cw)#http server
vx9000-3C6F18(config-management-policy-test-cw)#no https server
 no telnet
 http server
 nova
 flash-ui
 no https server
 rest-server
 ssh
Related commands
no Disables Flash UI access on the device
