preempt
Enables preemption of secondary tunnel, in case the primary tunnel goes down. This command also configures the delay time in preemption of the secondary tunnel.
Use this command to configure the time to wait before preempting the secondary tunnel.
Syntax
preemption delay <60-600>
Parameters
preemption delay <60-600> When the primary L2TPv3 tunnel goes down, the system waits and watches for the tunnel to come back, for a specified time, before preempting the secondary tunnel. Use this command to configure that time period.
  • delay <60-600> – Specify a value from 60 - 600 seconds. The default is 60 seconds.
nx9500-6C8809(config-profile test-l2tpv3-tunnel-tunnel1)#preemption delay 100
nx9500-6C8809(config-profile test-l2tpv3-tunnel-tunnel1)#show context
 l2tpv3 tunnel tunnel1
  preempt enable
Related Commands
no (l2tpv3-tunnel-config-mode-command) Disables preemption of secondary tunnel when primary tunnel comes back
