window-size (iot-device-type-imagotag-policy)
Configures the transmission window size for messages exchanged between ESL communicator and tags
Syntax
window-size <1-14>
Parameters
window-size <1-14>
window-size <1-14> Configures the window size
  • <1-14> – Specify a value from 1 - 14 bytes. The default value is 14 bytes.
Note: SES-Imagotags recommends NOT to change the default setting.
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#window-size 12
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  enable
  output-power Level-B
  window-size 12
  payload-size 25
  port 200
  ssl-enable
  fcc-enable
  channel 9
Related Commands
no (iot-device-type-imagotag-policy) Reverts the window-size to 14 bytes.
