crypto-cmp-policy-instance
The following table summarizes crypto CMP policy configuration commands:
Table 1. Crypto-CMP-Policy Config Mode Commands
Description
Command
ca-server
Configures the CA server details
cert-key-size Configures the size of the key associated with a certificate request
cert-renewal-timeout Configures a certificate renewal timeout in days
cross-cert-validate Enables validation of the cross certificate with the factory certificate
hash-algorithm Configures the hashing algorithm to be used by the CA to sign the digital certificate. This information is sent in the request for certification (new or renewal) to the CA server.
subjectAltName Configures an alternate subject name for this CMP policy
trustpoint
Configures a trustpoint and its associated information, such as the subject name, the sender‘s (device requesting certification) details, and the recipient's (CA) details
use
Associates a device‘s autogen-uniqueid with this crypto CMP policy
no
Removes the crypto CMP policy settings
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
