Configures an auto provisioning policy. This policy configures the automatic provisioning of device adoption. The policy configures how an AP is adopted based on its type.
auto-provisioning-policy <AUTO-PROVISIONING-POLICY-NAME>
<AUTO-PROVISIONING-POLICY-NAME> |
Specify the auto provisioning policy name. If the policy does not exist, it is created. |
NOC-NX9500(config)#auto-provisioning-policy test NOC-NX9500(config-auto-provisioning-policy-test)#? Auto-Provisioning Policy Mode commands: adopt Add rule for device adoption auto-create-rfd-template When RF Domain specified by the matching rule template does not exist create new RF Domain automatically default-adoption Adopt devices even when no matching rules are found. Assign default profile and default rf-domain deny Add rule to deny device adoption evaluate-always Set the flag to evaluate the policy everytime, regardless of previous adoption status no Negate a command or set its defaults redirect Add rule to redirect device adoption upgrade Add rule for device upgrade clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal NOC-NX9500(config-auto-provisioning-policy-test)#
no |
Removes an existing Auto Provisioning policy |
