upgrade-status
Displays the last image upgrade status
This command is not available in the USER EXEC Mode.
Syntax
show upgrade-status {detail|on}
show upgrade-status {detail} {(on <DEVICE-NAME>)}
Parameters
upgrade-status Displays last image upgrade status and log
detail Optional. Displays last image upgrade status in detail
on <DEVICE-NAME> The following keyword is recursive and common to the ‘detail' parameter:
  • on <DEVICE-NAME> – Optional. Displays last image upgrade status on a specified device
    • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
Note: If the ‘on‘ keyword is used without the ‘detail‘ keyword, the system displays a summary of upgrade status and log on the specified device.
nx9500-6C8809#show upgrade-status
Last Image Upgrade Status :In_Progress(17 percent completed)
Last Image Upgrade Time   : 2017-02-11 12:26:29
nx9500-6C8809#
nx9500-6C8809#show upgrade-status detail
Last Image Upgrade Status : Successful
Last Image Upgrade Time   : 2017-06-02 14:22:51
Running from partition /dev/sda8
var2 is 1 percent full
/tmp is 4 percent full
Free Memory 33357504 kB
FWU invoked via Linux shell
Validating image file header
Removing other partition
Tue May 30 10:43:36 IST 2017
debug: cmdline -C /boot/lilo.conf -R 5.9.0.0-028B -P fix
LILO version 22.6-CCB, Copyright (C) 1992-1998 Werner Almesberger
--More--
nx9500-6C8809#
