ldpc
interface-config-radio-instance
Enables support for Low Density Parity Check (LDPC) codes on the radio interface
LDPC consists of forward error correcting codes that enable error control in data transmission. This option is disabled by default.
Syntax
ldpc
Parameters
None
nx9500-6C8809(config-profile-Test510-if-radio1)#ldpc
nx9500-6C8809(config-profile-Test510-if-radio1)#show context
 interface radio1
  ldpc
Related Commands
no (radio-interface-config-command) Disables LDPC support
