Sends Internet Controller Message Protocol (ICMP) echo messages to a user-specified location
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.ping <IP/HOSTNAME> {count <1-10000>|dont-fragment {count|size}|size <1-64000>|
source [<IP>|pppoe|vlan <1-4094>|wwan]}
                         <IP/HOSTNAME>  |
                         Specify the destination IP address or hostname. When entered without any parameters, this command prompts for an IP address or a hostname.  |
                         count <1-10000>  |
                         Optional. Sets the pings to the specified destination
                         dont-fragment {count|size}  |
                         Optional. Sets the don‘t fragment bit in the ping packet. Packets with the dont-fragment bit specified are not fragmented. When a packet, with the dont-fragment bit specified, exceeds the specified maximum transmission unit (MTU) value, an error message is sent from the device trying to fragment it.
                         size <1-64000>  |
                         Optional. Sets the ping payload size in bytes
| source [<IP>|pppoe| vlan <1-4094>|wwan] | Optional. Sets the source address or interface
                        name. This is the source of the ICMP packet to the specified destination.
ap510-133B38#ping 10.234.160.5 PING 10.234.160.5 (10.234.160.5) 100(128) bytes of data. 108 bytes from 10.234.160.5: icmp_seq=1 ttl=64 time=0.283 ms 108 bytes from 10.234.160.5: icmp_seq=2 ttl=64 time=0.314 ms 108 bytes from 10.234.160.5: icmp_seq=3 ttl=64 time=0.314 ms 108 bytes from 10.234.160.5: icmp_seq=4 ttl=64 time=0.310 ms 108 bytes from 10.234.160.5: icmp_seq=5 ttl=64 time=0.312 ms --- 10.234.160.5 ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 4001ms rtt min/avg/max/mdev = 0.283/0.306/0.314/0.022 ms ap510-133B38#
nx9500-6C8809>ping 10.234.160.36 source vlan 1 PING 10.234.160.36 (10.234.160.36) from 10.234.160.5 vlan1: 100(128) bytes of data. 108 bytes from 10.234.160.36: icmp_seq=1 ttl=64 time=4.44 ms 108 bytes from 10.234.160.36: icmp_seq=2 ttl=64 time=0.532 ms 108 bytes from 10.234.160.36: icmp_seq=3 ttl=64 time=0.513 ms 108 bytes from 10.234.160.36: icmp_seq=4 ttl=64 time=0.587 ms 108 bytes from 10.234.160.36: icmp_seq=5 ttl=64 time=0.596 ms --- 10.234.160.36 ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 3998ms rtt min/avg/max/mdev = 0.513/1.334/4.443/1.554 ms nx9500-6C8809>
