interface-config-port-channel-instance
Configures the speed at which this port-channel interface receives and transmits data
speed [10|100|1000|auto]
speed [10|100|1000| auto] | Configure the data receive-transmit speed for this port channel. The options are:
Select either of these options to establish a 10, 100 or 1000 Mbps data transfer rate for the selected half duplex or full duplex transmission over the port. The auto option enables the port-channel to automatically exchange information about data transmission speed and duplex capabilities. Auto negotiation is helpful in an environment where different devices are connected and disconnected on a regular basis. |
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#speed 100 nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context interface port-channel1 description "This port-channel is for enabling dynamic LACP." speed 100 duplex full ipv6 nd trust ipv6 nd header-mismatch-validation spanning-tree portfast spanning-tree bpduguard enable spanning-tree bpdufilter enable spanning-tree mst 1 port-priority 1 spanning-tree mst 1 cost 20000 ip arp trust port-channel load-balance src-dst-mac nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#
no | Removes or reverts to default the speed at which this port-channel interface receives and transmits data |
