authorization
      Configures AAA TACACS authorization
         parameters. This feature allows network administrators to limit user accessibility and
         configure varying levels of accessibility for different users.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         authorization [access-method|allow-privileged-commands|server]
         authorization access-method [all|console|telnet|ssh] {(console|ssh|telnet)}
         authorization server [<1-2>|preference]
         authorization server <1-2> [host|retry-timeout-factor|timeout]
         authorizationserver <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
<SECRET>]} {port <1-65535>}
         authorization server <1-2> retry-timeout-factor <50-200>
         authorization server <1-2> timeout <3-5> {attempts <1-3>}
         authorization server preference [authenticated-server-host|authenticated-server-number|
none]
      Parameters
                     | access-method |
                     Configures the access method for command authorization |
                     | all |
                     Authorizes commands from all access methods |
                     | console |
                     Authorizes commands from the console only |
                     | telnet |
                     Authorizes commands from Telnet only |
                     | ssh |
                     Authorizes commands from SSH only |
                     | {console|ssh|telnet} |
                     Optional. Configures more than one access method for command
                        authorization |
         authorization allow-privileged-commands
                     | allow-privileged-commands |
                     Allows privileged commands execution without command authorization. This
                        option is disabled by default. |
         authorization server <1-2> host <IP/HOSTNAME> {secret [0 <SECRET>|2 <SECRET>|
                     | server <1-2> |
                     Configures a TACACS authorization server. Up to 2 TACACS servers can be
                           configured
                           - <1-2> – Specify
                              the TACACS server index from 1 - 2.
                     | host <IP/HOSTNAME> |
                     Sets the TACACS server‘s IP address or hostname |
                     | secret [0 <SECRET>| 2 <SECRET>|<SECRET>] |
                     Optional. Configures the secret used to authorize with the TACACS
                           server
                           - 0 <SECRET> –
                              Configures a clear text secret
                           - 2 <SECRET> –
                              Configures an encrypted secret
                           - <SECRET> –
                              Specify the secret key. The shared key should not exceed 127
                              characters.
                     | port <1-65535> |
                     Optional. Specifies the port used to connect to the TACACS server
                           - <1-65535> –
                              Specify a value for the TCP authorization port from 1 - 65535. The
                              default port is 49.
                     | server <1-2> |
                           configured
                           - <1-2> – Specify
                     | retry-timeout-factor <50-200> |
                     Configures the scaling of timeouts between consecutive TACACS
                        authorization retries
                           - <50-200> –
                              Specify the scaling factor from 50 - 200. The default is 100.
                         A value of 100 indicates the interval between consecutive retires
                           remains the same irrespective of the number of retries.
A value
                           lesser than 100 indicates the interval between consecutive retries
                           reduces with each successive retry.
A value greater than 100
                           indicates the interval between consecutive retries increases with each
                           successive retry.
                     | server <1-2> |
                           configured
                           - <1-2> – Specify
                              the TACACS server‘s index from 1- 2.
                     | timeout <3-5> |
                     Configures the timeout, in seconds, for each request sent to the TACACS
                        server. This is the time allowed to elapse before another request is sent to
                        the TACACS server. If a response is received from the TACACS server within
                        this time, no retry is attempted.
                           - <3-5> – Specify
                              a value from 3 - 5 seconds. The default is 3 seconds.
                     | attempts <1-3> |
                     Optional. Indicates the number of retry attempts to make before giving
                           up
                           - <1-3> – Specify
                              a value from 1 - 3. The default is 3.
none]
                     | preference |
                     Configures the authorization server preference |
                     | authenticated-server-host |
                     Sets the authentication server as the authorization server This
                           parameter indicates the same server is used for authentication and
                           authorization. The server is referred to by its hostname.
                     | authenticated-server- number |
                           authorization. The server is referred to by its index or
                        number.
                     | none |
                     Indicates the authorization server is independent of the authentication
                        server |
         nx9500-6C8809(config-aaa-tacacs-policy-test)#authorization allow-privileged-commands
         nx9500-6C8809(config-aaa-tacacs-policy-test)#show context
aaa-tacacs-policy test
 authentication directed-request
 accounting server preference authorized-server-number
 accounting auth-fail
 accounting commands
