interface-config-radio-instance
Sets the data-rate selection mode to standard or opportunistic
rate-selection [opportunistic|standard]
rate-selection | Sets the rate selection mode to standard or opportunistic |
standard | Configures the monotonic rate selection mode. This is the default setting. |
opportunistic | Configures the
opportunistic radio link adaptation (ORLA) rate selection
mode The ORLA algorithm is designed to select data rates that provide best throughput. Instead of using local conditions to decide whether a data rate is acceptable or not, ORLA pro-actively probes other rates to determine if greater throughput is available. If these other rates do provide improved throughput, ORLA intelligently adjusts its selection tables to favour higher performance. ORLA provides improvements both on the client side of a mesh network as well as in the backhaul capabilities. Note: The ORLA rate
selection mode is not supported on the new 802.11ax APs.
nx9500-6C8809(config-profile-testAP7161-if-radio1)#rate-selection opportunistic nx9500-6C8809(config-profile-testAP7161-if-radio1)#show context interface radio1 rate-selection opportunistic nx9500-6C8809(config-profile-testAP7161-if-radio1)#
no (radio-interface-config-command) | Resets the rate selection mode to standard (monotonic) |
