welcome-back
Enables the provision of direct Internet access to once-registered, captive-portal guest users on subsequent log-ins. When enabled, a registered captive-portal guest user, on subsequent logins, is served the Acknowledgement page only if:
Syntax
welcome-back pass-through
Parameters
welcome-back pass-through Enables display of the Acknowledgement page to an already registered user on subsequent captive-portal log-ins, provided the interval between logout and login is lesser than the agreement-refresh timeout
  • pass-through – Provides user direct Internet access, from the Welcome-back page, without any user action
nx9500-6C8809(config-captive-portal-test)#show context
captive-portal test
 webpage internal registration field city type text enable label "City" placeholder "Enter City"
 webpage internal registration field street type text enable label "Address" placeholder "123 Any Street"
 webpage internal registration field name type text enable label "Full Name" placeholder "Enter First Name, Last Name"
 webpage internal registration field zip type number enable label "Zip" placeholder "Zip"
 webpage internal registration field via-sms type checkbox enable title "SMS Preferred"
 webpage internal registration field mobile type number enable label "Mobile" placeholder "Mobile Number with Country code"
 webpage internal registration field age-range type dropdown-menu enable label "Age Range" title "Age Range"
 webpage internal registration field email type e-address enable mandatory label "Email" placeholder "you@domain.com"
 webpage internal registration field via-email type checkbox enable title "Email Preferred"nx9500-6C8809(config-captive-portal-test)#
Related Commands
no Disables the provision of direct Internet access to once-registered, captive-portal guest users on subsequent log-ins
