Configures the MTU for IPv4/IPv6 L2GRE tunnel endpoints
The MTU is the largest physical packet size (in bytes) transmittable within the tunnel. Any messages larger than the configured MTU are divided into smaller packets before transmission. Larger the MTU greater is the efficiency because each packet carries more user data, while protocol overheads, such as headers or underlying per-packet delays remain fixed; the resulting higher efficiency means a slight improvement in bulk protocol throughput. A larger MTU results in the processing of fewer packets for the same amount of data.
mtu [ipv4 <900-1476>|ipv6 <1236-1456>]
| mtu [ipv4 <900-1476>| ipv6 <1236-1456>] | Configures the MTU for L2GRE tunnel endpoints
nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#mtu ipv4 1200 nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#mtu ipv6 1300 nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#show context gre tunnel testGREtunnel mtu ipv4 1200 mtu ipv6 1300 establishment-criteria rf-domain-manager nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#
