Use this command to view MAC authentication configuration and authentication state. The command displays the current authentication state of the wired host, the authorization state of the Ge1 port, and the wired hosts‘ MAC address. The port status displays as Authorized if the wired host has successfully authenticated and Not Authorized if the wired host has not authenticated or has failed MAC authentication.
For more information on enabling MAC address authentication on a wired port, see mac-auth (profile-config-mode).
show mac-auth {all|interface|on}
show mac-auth {all|interface [<INTERFACE-NAME>|ge <1-5>|port-channel <1-3>|
t1e1 <1-4>|up <1-2>|xge <1-4>]} {(on <DEVICE-NAME>)}
| macauth | Displays MAC authentication related information for all interfaces or a specified interface |
| all |
| interface [<INTERFACE-NAME>|ge <1-5>| port-channel <1-3>| t1e1 <1-4>|up <1-2>| xge <1-4>] |
Optional. Displays MAC authentication related information for a specified interface. Specify the interface using one of the following options:
| on <DEVICE-NAME> | The following keywords are common to the ‘all‘ and ‘interface‘
parameters:
Note: When the ‘on‘
keyword is used exclusively, without the ‘all‘ and ‘interface‘ options,
the system displays MAC authentication related information for interfaces
configured on the specified device.
nx9500-6C8809(config)#show mac-auth all AAA-Policy is none Mac Auth info for interface GE1 ----------------------------------- Mac Auth Enabled Mac Auth Not Authorized Mac Auth info for interface GE2 ----------------------------------- Mac Auth Disabled Mac Auth Not Authorized Mac Auth info for interface GE3 ----------------------------------- Mac Auth Disabled Mac Auth Not Authorized Mac Auth info for interface GE4 ----------------------------------- Mac Auth Disabled Mac Auth Authorized Mac Auth info for interface GE5 ----------------------------------- Mac Auth Disabled Mac Auth Not Authorized Mac Auth info for interface UP1 ----------------------------------- Mac Auth Disabled Mac Auth Not Authorized nx9500-6C8809(config)#
