In all the three scenarios the access time consumed is the duration for which the guest user has logged.
show radius [guest-users|server]
show radius guest-users {brief|<GUEST-USER-NAME>}
show radius server
radius guest-users {brief|<GUEST-USER-NAME>} | Displays RADIUS server‘s guest user‘s access details: total time for which the
user has logged in, and the amount of access time remaining.
Use this command in the captive-portal context to view time and data statistics for guest user(s) having bandwidth-based or time-based vouchers configured. In such a scenario, the system displays the following information: data configured, data remaining, configured and current bandwidths (for both downlink and uplink), time configured, and time remaining. If bandwidth-based voucher is not applicable to a guest user, the data configured and data remaining values are displayed as ‘unlimited‘. The bandwidth columns are blank. If time-based voucher is not applicable to a guest user, the only value displayed is the time remaining (which is the time till the expiration of the guest user‘s account). Note: For
more information on configuring bandwidth-based and time-based vouchers, see user (radius user policy config mode).
show radius server
radius server | Displays RADIUS server related statistical data |
nx9500-6C8809#show radius guest-users TIME (min:sec) USED REMAINING GUEST USER 0:00 9:00 time9 0:00 5:00 time5 0:00 15:00 time15 0:00 305416:35 notime 2:31 7:29 time10 nx9500-6C8809#
The following example shows a RADIUS user pool with guest users having bandwidth-based, time-based, bandwidth and time based, and no bandwidth or time based vouchers:
nx9500-6C8809(config-captive-portal-wdws)#show context radius-user-pool-policy wdws user time_and_data password 0 both group wdws guest expiry-time 12:00 expiry-date 12/31/2015 access-duration 8000 data-limit 500 committed-downlink 3000 committed-uplink 2000 reduced-downlink 1000 reduce4 user neither password 0 nine group wdws guest expiry-time 12:00 expiry-date 12/31/2015 user data_only password 0 data group wdws guest expiry-time 12:00 expiry-date 12/31/2015 data-limit 125 committed-downlink 1000 committed-uplink 800 reduced-downlink 500 reduced-uplink 400 nx9500-6C8809(config-captive-portal-wdws)#
The following example shows the captive portal access details for the above mentioned RADIUS user pool users:
nx9500-6C8809(config-captive-portal-wdws)#show radius guest-users TIME (DD:HH:MM:SS) DATA (kilobytes) BANDWIDTH (kbps) GUEST USER CONFIGURED REMAINING CONFIGURED REMAINING CFGD DN CURR DN CFGD UP CURR UP time_and_data 5:13:20:00 5:12:00:50 512000 433727 3000 0 2000 0 neither till expiry 221:19:44:54 unlimited unlimited data_only till expiry 221:19:44:54 128000 127587 1000 0 800 0 time_only 3:11:20:00 3:11:19:47 unlimited unlimited Current time: 17:15:07 nx9500-6C8809(config-captive-portal-wdws)#
