qos
interface-config-port-channel-instance
Configures Quality of Service (QoS) related parameters on this port-channel interface
Syntax
qos trust [802.1p|dscp]
Parameters
qos trust [802.1p|dscp] Configures the following QoS related parameters:
  • 802.1p – Trusts 802.1p class of service (COS) values ingressing on this port channel. This option is enabled by default.
  • dscp – Trusts IP DSCP QOS values ingressing on this port channel. This option is enabled by default.
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#qos trust dscp
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
Related Commands
no Removes the QoS related parameters configured on this port-channel interface
