netbios-name-server (dhcpv4-pool-config)
Configures the NetBIOS (WINS) name server‘s IP address. This server is used to resolve NetBIOS host names.
Syntax
netbios-name-server [<IP>|<HOST-ALIAS-NAME>] {<IP1>|<HOST-ALIAS-NAME1>}
Parameters
[<IP>|<HOST-ALIAS- NAME>]
Configures the primary NetBIOS name server, using one of the following options:
  • <IP> – Specifies the primary NetBIOS name server‘s IP address
  • <HOST-ALIAS-NAME> – Specifies a host alias, mapped to the primary NetBIOS name server‘s IP address
{<IP1>|<HOST-ALIAS- NAME1>}
Optional. Configures the secondary NetBIOS name server, using one of the following options:
  • <IP1> – Specifies the secondary NetBIOS name server‘s IP address
  • <HOST-ALIAS-NAME1> – Specifies a host alias, mapped to the secondary NetBIOS name server‘s IP address. If the primary NetBIOS name server is unavailable, the secondary server is used.
Note: A network host alias maps a name to a single network host. For example, ‘alias host $HOST 1.1.1.100‘. In this example the host alias is ‘$HOST‘ and it maps to a single host ‘1.1.1.100‘. For more information, see alias.
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#netbios-name-server 192.168.13.25
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  network 192.168.13.0/24
  address 192.168.13.4 class dhcpclass1
  lease 100 23 59 59
  ddns server 192.168.13.9
  ddns domainname WID
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  domain-name documentation
  bootfile test.txt
  default-router 192.168.13.8 192.168.13.9
  dns-server 192.168.13.19
Related Commands
no Removes the NetBIOS name server settings
