crypto-cmp-cert-update
Triggers a CMP
(Certificate Management Protocol) certificate update on a
specified device or devices
This command and its
syntax is common to both the
User Executable and
Privilege
Executable configuration modes.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
crypto-cmp-cert-update <TRUSTPOINT-NAME> {on <DEVICE-NAME>}
Parameters
| crypto-cmp-cert-update <TRUSTPOINT-NAME> on <DEVICE-NAME> |
Triggers a CMP certificate update on a specified device or devices
- <TRUSTPOINT-NAME> –
Specify the target trustpoint name. A trustpoint represents a CA/identity pair
containing the identity of the CA, CA specific configuration parameters, and an
association with an enrolled identity certificate. Use the crypto-cmp-policy
context mode to configure the trustpoint.
- on <DEVICE-NAME> –
Optional. Initiates a CMP certificate update and response on a specified
device or devices. Specify the name of the AP, wireless controller, service
platform or virtual platform. Multiple devices can be provided as a comma
separated list.
- <DEVICE-NAME> –
Specify the name of the AP, wireless controller, service platform or
virtual platform.
NOC-NX9500#crypto-cmp-cert-update test on B4-C7-99-71-17-28
CMP Cert update success
NOC-NX9500#
