ip
Configures IP default gateway priority
Syntax
ip default-gateway priority <1-8000>
Parameters
default-gateway Configures the default gateway
priority <1-8000> Sets the priority for the default gateway acquired via OSPF
  • <1-8000> – Specify an integer from 1 - 8000. The default is 7000.
Note: Lower the value, higher is the priority.
nx9500-6C8809(config-profile default-ap8533-router-ospf)#ip default-gateway priority 1
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
Related Commands
no (router-mode-config-command) Removes default gateway priority settings
