no
interface-config-vlan-instance
Negates a command or reverts to defaults. The no command, when used in the Config Interface VLAN mode, negates VLAN interface settings or reverts them to their default.
Syntax
no [crypto|description|dhcp|dhcp-relay-incoming|ip|ipv6|shutdown|use]
no dhcp client include client-identifier
no [crypto map|description|dhcp-relay-incoming|shutdown]
no ip [address|dhcp|helper-address|nat|ospf]
no ip [helper-address <IP>|nat]
no ip address {<IP/M> {secondary}|<NETWORK-ALIAS-NAME> {secondary}|dhcp|zeroconf {secondary}}
no ip dhcp client request options all
no ip ospf [authentication|authentication-key|bandwidth|cost|message-digest-key| priority]
no ipv6 [accept|address|dhcp|enable|enforce-dad|mtu|redirects|request-dhcpv6-options|router-advertisement]
no ipv6 [accept ra|enable|enforce-dad|mtu|redirects|request-dhcpv6-options]
no ipv6 address [<IPv6/M>|autoconfig|eui-64|link-local|prefix-from-provider>]
no ipv6 dhcp [client|relay]
no ipv6 router-advertisement [prefix <WORD>|prefix-from-provider <WORD>]
no use [bonjour-gw-discovery-policy>|ip-access-list in|ipv6-access-list in|ipv6-router-advertisement-policy|url-filter]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or reverts this VLAN interface‘s settings based on the parameters passed
The following example shows the VLAN interface settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#show context
 interface vlan8
  description "This VLAN interface is configured for the Sales Team"
  ip address 10.0.0.1/8
  ip helper-address 172.16.10.3
  ip nat inside
  crypto map map1
  dhcp-relay-incoming
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#no crypto map
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#no description
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#no dhcp-relay-incoming
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#no ip dhcp client request options all
The following example shows the VLAN interface settings after the ‘no‘ commands are executed:
 interface vlan8
  ip nat inside
