The no command reverts the selected captive portal‘s settings or resets settings to default.
no [access-time|access-type|accounting|bypass|connection-mode|custom-auth|data-limit| frictionless-onboarding|inactivity-timeout|ipv6|localization|logout-fqdn|oauth|php-helper| post-authentication-vlan|radius-vlan-assignment|redirection|report-loyalty-application|server| simultaneous-users|terms-agreement|use|webpage|webpage-auto-upload|webpage-location|welcome-back]
no [access-time|access-type|connection-mode|data-limit|frictionless-onboarding| inactivity-timeout|logout-fqdn|post-authentication-vlan|radius-vlan-assignment| report-loyalty-application|simultaneous-users|terms-agreement|webpage-auto-upload |webpage-location]
no accounting [radius|syslog]
no bypass captive-portal-detection
no custom-auth info
no ipv6 server host
no localization [fqdn|response]
no oauth {client-id}
no php-helper
no redirection ports
no server host
no server mode {centralized-controller [hosting-vlan-interface]}
no use [aaa-policy|dns-whitelist]
no webpage external [acknowledgement|agreement|fail|login {post}|no-service|
registration|welcome]
no webpage internal [acknowledgement|agreement|fail|login|no-service|org-name| org-signature|registration|welcome]
no webpage internal [org-name|org-signature]
no webpage internal [acknowledgment|agreement|fail|login|no-service] [body-background-color|body-font-color|description|footer|header|main-logo|org-background-color| org-font-color|small-logo|title]
no webpage internal registration [body-background-color|body-font-color|description|field| footer|header|main-logo|org-background-color|org-font-color|small-logo|title]
no webpage internal registration field [age-range|city|country|custom <FIELD-NAME>|
disclaimer|dob|email|gender|member|mobile|name|optout|street|via-email|via-sms|zip] {enable}
no webpage internal welcome [body-background-color|body-font-color|description|footer| header|main-logo|org-background-color|org-font-color|small-logo|title|use-external-success-url]
no welcome-back pass-through
no <PARAMETERS>
no <PARAMETERS> |
Removes or resets this captive portal‘s settings, based on the parameters passed. |
The following example shows the captive portal ‘test' settings before the ‘no' commands are executed:
nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-type logging access-time 35 custom-auth info bob bob@examplecompany.com connection-mode https inactivity-timeout 750 accounting syslog host 172.16.10.13 port 1 nx9500-6C8809(config-captive-portal-test)#
nx9500-6C8809(config-captive-portal-test)#no accounting syslog
nx9500-6C8809(config-captive-portal-test)#no access-type
The following example shows the captive portal ‘test' settings after the ‘no' commands are executed:
nx9500-6C8809(config-captive-portal-test)#show context captive-portal test access-time 35 custom-auth info bob bob@examplecompany.com connection-mode https inactivity-timeout 750 nx9500-6C8809(config-captive-portal-test)#
