passive
Configures specified OSPF interface as
passive. This option is disabled by default.A passive interface receives routing
updates, but does not transmit them.
- Access Points — AP410i/e, AP460i/e,
AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
AP8533
Syntax
passive [<WORD>|all|vlan <1-4094>]
Parameters
<WORD> |
Enables the OSPF passive mode on the interface specified by the
<WORD> parameter |
all |
Enables the OSPF passive mode on all the L3 interfaces |
vlan <1-4094> |
Enables the OSPF passive mode on the specified VLAN interface
- <1-4094> –
Specify the VLAN interface ID from 1 - 4094.
nx9500-6C8809(config-profile default-ap8533-router-ospf)#passive vlan 1
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
router ospf
ospf enable
network 1.2.3.0/24 area 4.5.6.7
area 0.0.0.4
auto-cost reference-bandwidth 1
default-information originate metric 1 metric-type 2
passive vlan1
ip default-gateway priority 1
