no (ex3500-qos-policy-map)
Removes this EX3500 QoS policy map's settings. Use this keyword to remove the description and to remove the QoS traffic classification created.
Syntax
no [class <EX3500-QoS-POLICY-MAP-NAME>|description]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes this EX3500 QoS policy map's settings based on the parameters passed
The following example shows the EX3500 QoS policy map ‘test‘ settings before the ‘no‘ command are executed:
nx9500-6C8809(config-ex3500-qos-policy-map-test)#show context
ex3500-qos-policy-map test
 description "This is a test EX3500 QoS Policy Map"
 class test
EX3500(config-ex3500-qos-policy-map-test)#no description
EX3500(config-ex3500-qos-policy-map-test)#no class test
The following example shows the EX3500 QoS policy map ‘test‘ settings after the ‘no‘ command are executed:
EX3500(config-ex3500-qos-policy-map-test)#show context
