ssl (iot-device-type-imagotag-policy)
Enables secure, encrypted communication over the Secure Socket Layer (SSL) between the AP and SES-imagotag server. This option is disabled by default.
Important
Important
It is mandatory to configure ssl parameter for encrypted connection.
Syntax
ssl
Parameters
ssl-cn-verify
ssl-strict-verify
trustpoint ESL
ssl parameter enables ssl on ESL communicator. This is a mandatory parameter.
ssl-cn-verify and ssl-strict-verify parameters are required to perform certificate validation for hostname (or IP address) in server certificate. If ssl-cn-verify is configured and ESL server IP or hostname doesn't match the IP or hostname in certificate common-name, then the connection request is rejected.
trustpoint ESL parameter is required to specify a configured trustpoint which points to CA or self-signed certificate. This parameter is required with ssl parameter.
For cleartext communication, you do not need to provide IP or host configuration for the default port. However, for secure communication, you must provide default secure port.
Important
Important
Do not enable policy before configuring the access point in ESL on-prem or cloud server.
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#ssl
nx9500-6C8809(config-iot-device-type-imagotag-policy-ImagoTagPolicy)#show context
 iot-device-type-imagotag-policy ImagoTagPolicy
  enable
  output-power Level-B
  payload-size 25
  port 200
  ssl
  fcc-enable
  channel 9
Configure IoT Imagotag policy example
ap410-FD26D0(config-iot-device-type-imagotag-policy-VCLOUD)#ssl?
ssl                Enable ssl on ESL communicator [MANDATORY]
ssl-cn-verify      Enforce SSL Common Name attribute verification [OPTIONAL]
ssl-strict-verify  Enforce SSL strict verification [OPTIONAL]
ap410-FD26D0(config-iot-device-type-imagotag-policy-VCLOUD)#channel ?
<0-10>   ESL channel number
acs      Automatic ESL channel selection on AP
managed  ESL channel managed from ESL server [OPTIONAL]
Important
Important
managed channel mode should only be configured on new deployments.
trustpoint policy example
ap410-FD26D0(config-iot-device-type-imagotag-policy-VCLOUD)#trustpoint ?
WORD  Trustpoint name
trustpoint attaches configured trustpoint to policy to be used for encrypting communications.
Use configured IoT Imagotag policy example
ap310-FD8A61#show running-config profile ap310 default-ap310
no autoinstall configuration
no autoinstall firmware
device-upgrade auto ap310 ap360
crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
crypto ikev2 policy ikev2-default
crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
crypto ikev1 remote-vpn
crypto ikev2 remote-vpn
crypto auto-ipsec-secure
crypto load-management
crypto remote-vpn-client
interface radio1
  no 11axSupport
interface radio2
  no 11axSupport
interface bluetooth1
  shutdown
  mode le-sensor
interface ge1
interface ge2
interface vlan1
  ip address dhcp
  ip dhcp client request options all
interface pppoe1
use firewall-policy default
rf-domain-manager capable
logging on
logging console debugging
logging buffered debugging
no service pm sys-restart
router ospf
dpi metadata http
dpi metadata ssl
adoption-mode controller
 use iot-device-type-imagotag-policy
ap310-FD8A61#
Verify status of Imagotag policy
You need to configure the AP-ID value in ESL on-prem server or cloud server to on-board an access point. This value is found in the AP-ID column.
nx5500-85FA27#show iot-device-type-imagotag status
Policy Name        Status      USB dongle    AP-ID AP-MAC            AP-NAME              Channel  Window Payload Power SSL
                               State                                                               Size   Size    Level Status
                   Disabled    Disconnected      0 94-9B-2C-13-3B-2E ap510-133B2E          (ACS) 3      0       0     A Disabled
Total number of devices displayed: 1
ACS: Automatic Channel Selection (automatically selected by AP)
SCS: Server Channel Selection (selected/managed by server)
nx5500-85FA27#
Related Commands
no (iot-device-type-imagotag-policy) Disables SSL encryption mode of communication
