Removes address(es) configured with this NAT pool
no address [<IP>|range <START-IP> <END-IP>]
no address [<IP>| range <START-IP> <END-IP>] | Removes a single IP address or a range of IP addresses from this NAT pool |
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#show context ip nat pool pool1 address range 172.16.10.2 172.16.10.8 nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)# nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#no address range 1 72.16.10.2 172.16.10.8 nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#show context ip nat pool pool1 nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#
