roam-consortium
Configures a list of RC (Roaming Consortium) OIs (Organization Identifiers) supported on this hotspot. The beacons and probe responses communicate this Roaming Consortium list to devices. This information enables a device to identify the networks available through this AP.
Each OI identifies a either a group of SSPs (Subscription Service Providers) or a single SSP.
Syntax
roam-consortium hex <WORD>
Parameters
Adds a Roaming Consortium OI to this hotspot in hexadecimal format
  • <WORD> – Specify the Roaming Consortium OI in hexadecimal format (should not exceed 128 characters)
hex <WORD>
Configures a hexadecimal input
nx9500-6C8809(config-passpoint-policy-test)#roam-consortium hex 223344
nx9500-6C8809(config-passpoint-policy-test)#show context
passpoint-policy test
 access-network-type chargeable-public
 connection-capability ip-protocol 2 port 10 closed
 nai-realm example
  eap-method 1 ttls auth-param vendor hex 00001E
  eap-method 2 rsa-public-key auth-param credential cert
 net-auth-type accept-terms url www.test.com
 operator name exampleoperator
 3gpp mcc 505 mnc 14
 osu ssid test
 osu provider test
  name testOSU
  method soap-xml-spp priority 2
  nai test.org
  server-url test.exampe.com
Related Commands
no
Removes the Roaming Consortium OIs supported on this passpoint policy
