radio-share-mode
interface-config-radio-instance
Configures the radio‘s mode of operation as radio share. A radio operating in the radio share mode services clients and also performs sensor functions (defined by the radio‘s ADSP licenses and profiles).
The sensor capabilities of the radio are restricted to the channel and WLANs defined on the radio.
Syntax
radio-share-mode [inline|off|promiscuous]
Parameters
radio-share-mode Enables sharing of packets, switched by this radio, with the WIPS sensor module. There are two radio-share modes, these are: inline and promiscuous
inline Enables sharing of all WLAN packets (matching the BSSID of the radio) serviced by the radio with the WIPS sensor module.
off Disables radio share (no packets shared with the WIPS sensor module)
promiscuous Enables the promiscuous radio share mode. In this mode the radio is configured to receive all packets on the channel irrespective of whether the destination address is the radio or not, and shares these packets with the WIPS sensor module for analysis (i.e. without filtering based on BSSI).
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#radio-share-mode promiscuous
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  power 12
  data-rates b-only
  placement outdoor
  mesh client
  off-channel-scan channel-list 2.4GHz 1
  preamble-short
  guard-interval long
  non-unicast queue bss 16 50
  antenna-diversity
  max-clients 100
  airtime-fairness prefer-ht weight 6
  lock-rf-mode
  extended-range 15
  antenna-downtilt
Related Commands
no (radio-interface-config-command) Resets the radio share mode for this radio to its default
