The first step in creating a WLAN is to configure a profile defining the parameters applied to a wireless controller.
rfs4000(config)#profile rfs4000 RFS4000_UseCase1 rfs4000(config-profile-RFS4000_UseCase1)#
This creates a profile with the name RFS400_UseCase1 and moves the cursor into its context. Any configuration made under this profile is available when it is applied to a device.
rfs4000(config-profile-RFS4000_UseCase1)#interface vlan 2 rfs4000(config-profile-RFS4000_UseCase1-if-vlan2)#ip address 172.16.11.1/24
The above command assigns the IP address 172.16.11.1 with the mask of 255.255.255.0 to VLAN2. Exit the VLAN2 context.
rfs4000(config-profile-RFS4000_UseCase1-if-vlan2)#exit rfs4000(config-profile-RFS4000_UseCase1)#
The next step is to assign this newly created VLAN to a physical interface. In this case, VLAN 2 is mapped to GE3 and GE4 to support two access points, an AP 7602 and AP 7161. The AP 7602 is connected to the gigabit interface GE3 and the AP 7161 to the GE4 interface.
rfs4000(config-profile-RFS4000_UseCase1)#interface ge 3 rfs4000(config-profile-RFS4000_UseCase1-if-ge3)#
rfs4000(config-profile-RFS4000_UseCase1-if-ge3)#switchport access vlan 2 rfs4000(config-profile-RFS4000_UseCase1-if-ge3)#exit rfs4000(config-profile-RFS4000_UseCase1)#
rfs4000(config-profile-1_UseCase1)#interface ge 4 rfs4000(config-profile-RFS4000_UseCase1-if-ge4)#switchport access vlan 2 rfs4000(config-profile-RFS4000_UseCase1-if-ge4)#exit rfs4000(config-profile-RFS4000_UseCase1)#
rfs4000(config-profile-RFS4000_UseCase1)#exit rfs4000(config)#commit write memory
rfs4000(config)#self rfs4000(config-device-03-14-28-57-14-28)# rfs4000(config-device-03-14-28-57-14-28)#use profile RFS4000_UseCase1 rfs4000(config-device-03-14-28-57-14-28)#exit rfs4000(config)#commit write
rfs4000(config)#wlan 1 rfs4000(config-wlan-1)#
rfs4000(config-wlan-1)#ssid WLAN_USECASE_01
rfs4000(config-wlan-1)#broadcast-ssid
The WLAN created for this usecase, is an open WLAN, with no authentication mode specified. Once the WLAN is mapped to an AP, clients will not require password for associating with the WLAN through the AP.rfs4000(config-wlan-1)#vlan 2 rfs4000(config-wlan-1)#exit
