Use the crypto command to define a system-level local ID for Internet Security Association and Key Management Protocol (ISAKMP) negotiation and to enter the ISAKMP policy, ISAKMP client, or ISAKMP peer command set.
The following table summarizes crypto configuration mode commands:
Command | Description |
crypto | Invokes commands used to configure ISAKMP policy, ISAKMP client, and ISAKMP peer |
crypto-auto-ipsec-tunnel commands | Creates an auto IPSec VPN tunnel and enters its configuration mode |
crypto-ikev1/ikev2-policy commands | Creates a crypto IKEv1/IKEv2 policy and enters its configuration mode |
crypto-ikev1/ikev2-peer commands | Creates a IKEv1/IKEv2 peer and enters its configuration mode |
crypto-map-config-commands | Creates a crypto map and enters its configuration mode |
crypto-remote-vpn-client commands | Creates a remote VPN client and enters its configuration mode |
