| Command | Description |
| custom-scan | Configures the channel scanning settings when the scan-mode is set to custom-scan |
| rssi-interval-duration | Configures the interval at which dedicated sensors scan channels for RSSI assessments and send the collected data to a specified MPact server resource |
| scan-mode | Configures the mode of scanning used by dedicated sensors (access point radios) |
| no (sensor-policy-config-mode-commands) | Removes or reverts to default a sensor policy‘s settings |
