Access Points — AP 6522, AP 6532, AP 6562, AP 7161, AP 7502, AP-7522, AP 7532, AP-7562, AP7632, AP7662, AP-8432, AP-8533
hysteresis [min-threshold|period|root-sel-snr-delta|snr-delta]
hysteresis [min-threshold <-100-0>|period <0-600>|root-sel-snr-delta <1-100>| snr-delta <1-100>]
| min-threshold <-100-0> | Configures the minimum signal strength that a
device should have to be considered a likely candidate in the mesh route (to
the mesh root node) selection process.
period <0-600> |
Configures the interval, in seconds, for which a likely candidate‘s path method hysteresis is sustained. In other words a device capable of sustaining the signal strength for the specified period of time is a likely candidate in the mesh route (to the mesh root node) selection process.
root-sel-snr-delta <1-100> |
Configures the signal strength, in dB, that a device has to sustain, within the delta range, to be considered a likely candidate in the mesh route (to the mesh root node) selection process.
snr-delta <1-100> |
Configures the SNR delta. The device with must have a SNR of a greater delta than its current neighbor to be considered a likely candidate in the mesh route (to the mesh root) selection process.
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#hysteresis period 15
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#hysteresis root-sel-snr-delta 12
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#hysteresis snr-delta 3
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#hysteresis min-threshold -65
rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#show context meshpoint-device test hysteresis period 15 hysteresis snr-delta 3 hysteresis min-threshold -65 hysteresis root-sel-snr-delta 12 rfs4000-229D58(config-profile-testAP71XX-meshpoint-test)#
| no (meshpoint-device-config) |
Removes the configured path selection SNR hysteresis values |
